PLM Guidance
September 14, 2018
3926
Data Mapping
in Ravenhill PLM Guidance
by
Data Mapping Records of work done can be logged by the displays and taken back to the office for analysis / record keeping: Intelliview IV displays on tractors & harvesters can automatically log in the background useful info such as; crop yield, moisture,…
READMORE
September 14, 2018
3966
ISOBUS Task Controller (ISO TC)
by
ISOBUS Task Controller (ISO TC) The next evolution from TUVR: An Isobus implement can be connected to either an Intelliview IV, XCN-1050 or XCN-2050 display, showing both the implement operating screen and controlling rate / section at the same time via GPS…
READMORE
September 14, 2018
4122
Serial Rate Control / TUVR
by
Serial Rate Control / TUVR The GPS display can take over control of your compatible fertiliser spreader or sprayer control box Depending on the implement capabilities, this can alter the rate according to prescription maps and/or section control This can…
READMORE
September 14, 2018
3883
New Holland Intellisteer System
by
New Holland Intellisteer System Our fully integrated, high-performance solution on New Holland machinery: Uses the integrated Intelliview IV display Utilises the original Intellisteer-ready valves & steering sensor Highest performance and accuracy Simplified…
READMORE
September 14, 2018
3929
Autosteer Ready System
by
Autosteer Ready System Aftermarket option for vehicles with factory autosteer-ready systems: Available for the FM-750, XCN-1050 and XCN-2050 displays Utilises the original factory fit steering valves / sensors - regardless of brand Highest performance and…
READMORE
September 14, 2018
4207
AutoPilot Hydraulic Aftermarket System
by
AutoPilot Hydraulic Aftermarket System High-accuracy solution for machines that are not autosteer-ready: Available for the FM-750, XCN-1050 and XCN-2050 displays Uses hydraulic valves and pipework specifically designed for each machine High performance using…
READMORE
September 14, 2018
4205
Ez Pilot Pro Assisted Steering System
by
Ez Pilot Pro Assisted Steering System New high-performance assisted system designed for the XCN-1050 display & NAV-900 controller: High accuracy from the column-mounted SAM200 steering motor Uses the NAV-900 guidance controller for reduced components and…
READMORE
September 14, 2018
3938
Ez Pilot Assisted Steering System
by
Ez Pilot Assisted Steering System The next step from your lightbar unit – add hands free steering and let the motor follow the line: Compatible with the FM-750 and XCN-2050 displays Reduce overlaps and increase productivity whilst letting you concentrate more…
READMORE
September 14, 2018
4082
New Holland Intelliview IV
by
New Holland Intelliview IV Our integrated display option packed with the following features: Clear 26.4cm touchscreen display Compatible with New Holland tractors, harvesters and implements Monitor and control vehicle functions and performance Tractors: HTS2…
READMORE
September 14, 2018
3878
XCN2050
by
XCN2050 The flagship display in our aftermarket offering: Large Android-based 30.8cm high definition touchscreen display Rugged tablet-like display designed for agricultural environments Choice of Precision IQ or FM1000+ interfaces depending on user needs Use…
READMORE
September 14, 2018
4122
XCN1050
by
XCN1050 Our latest aftermarket display built with flexibility and ease-of-use in mind: Android-based 25.6cm high definition touchscreen display Quality, rugged device designed for agricultural environments Roof-mounted NAV900 combined receiver & guidance…
READMORE
September 14, 2018
3897
Ez Guide 250
by
EZ Guide 250 Our entry-level lightbar unit boasting the following features: Rugged yet compact build with 10.9cm colour display Simple setup – a few button presses and you’re ready to go Easy to follow with 15 bright LEDs to guide you Multiple patterns…
READMORE
September 14, 2018
4061
FM750 Lite
by
FM750 LITE A feature-packed lightbar unit with upgrade potential: 20.3cm vivid touchscreen display Intuitive setup and use 27 bright LEDs to guide you on your way Multiple patterns including AB, curve and headland Field and coverage data can be saved to USB…
READMORE
June 02, 2016
5607
PLM Specialist PLM Page
by
New PLM Specialist for our Scottish Depots We are pleased to announce Steven Morrison as our new full-time PLM / Product Specialist for our Scottish branches. Ravenhill realise the need for a dedicated support in this rapidly growing and exciting area, and…
READMORE
